Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Ottawa 6 spd owners.
Old Nov 23, 2007 | 07:58 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I dont know many F-body owners in Ottawa. Just my bro, one of his freinds, and Kyle, who i traded parts with.
But anyways, i know a couple of you on this board are from Ottawa, and couple of those have T56 or tremecs or TKOs or something.
For those of you who bought used, just curious where you folks got it?
I have my budget lined up, and im in store for a T56 over the winter. QUALITY is my number 1 concern, more than time. And money a little bit too.
Any input appreciated.
P.S.
If you are going to post suggestions about lookin on the internet, i got that part covered pretty well, im looking for other tips, like some secret junk yard or a swap meet i dont know about But again, any input is good.
Old Nov 24, 2007 | 08:10 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: Ottawa 6 spd owners.
Hmm, I think I might be one of the only othet guys.
I've had my T56 in the IROC for 8 yrs now I think.
I found it used from a guy in TO who was going to put it in a rod. It was $800. A friend spotted it after in a lesser known old car newspaper his shop gets.
I'd say keep an eye on guys parting cars out on the boards, 4th and 3rd gens. Try Arnprior Auto locally, get them to jump on the inter-wrecker computer system to find one.
I also got some parts (pedals/bellhousing/flywheel/used clutch) at Cookstown Auto Centre Ltd - 5046 5 Sideroad, Cookstown, ON L0L 1L0 (705) 458-4366. They had a 95 Z to part out and were good guys.
I'd also recommend tyring to get a bellhousing that will allow you to run an older push style clutch as the LT1 style clutches are pretty expensive and there are not many choices for pressure plates (there are maybe 3).
Good luck.
Old Nov 24, 2007 | 11:14 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Thats exactly the kind of info i was looking for. Thanks for the tips. I gotta get my hands on one of those newspapers, i sold my last car thanks to one.
Actually there is one other guy, but hes not on this board that has a 6spd. He just installed it last year i think. A freind of a freind kinda thing, he goes to the shows in Toronto every year, and he has a nicely built car. Name is kyle, he has a red camaro, and you can recognize his car cuz it has a second gen spoiler, except it looks like its part of the car, not just bolted on. Very nicely done.
Old Nov 24, 2007 | 11:06 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
See if the guys at www.ccfbg.com can help. Post up in the wanted section. The "who you know" route may cost you less.
Old Nov 24, 2007 | 11:49 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Who you know route? What do u mean? Make freinds and make a deal at speedorama?
Old Nov 28, 2007 | 10:34 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I think Kyle just put his T56 in recently. I thought he use to run a 700R4 before?
Old Nov 28, 2007 | 04:55 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
i think so, ive only met him once, nice guy, and his dad owns some really sweet cars.
He told me he had just put it in, it was over the summer. And yea i think he did run a 700r4 before, he was telling me how easy it was to swap over cuz of the similariteis between the two.
Old Dec 4, 2007 | 03:35 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Where are you guys located? I live in Gloucester near the Split. Would one of you guys be interested in meeting up, (me coming to see your car basically) for a crash course in whats involved with installing this thing?
I got most of it down with the tech articles, but still not sure about the pedals and the clucth part.
Would be nice to see the finished product.
Old Dec 5, 2007 | 07:46 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
There's not really much to see for the pedals and clutch with the car together.
I just got a set from I think an 85 firebird, they bolt right in. You'll need to drill out the floor to get the hydraulic slave installed. It mounts with a U shaped bolt fromthe engine side, you should get the bolt with the pedals. I think the pattern is even on the firewall already.
I used a new 4th gen slave and had to shorten the actuating rod by about 1/2" if I remember right. The 3rd and 4th gen slaves mount the same in the car. The LT1 style clutch bolted right up to the LT1 flywheel. I used the same flywheel on my old 86 305 (1pc rear main seal) and the new 95 LT1.
That's it, not much to it. It was harder to fab up a cross member and figure out the speedo drive.
Let me know if you have any more specific questions...
If you want to meet up, we could in the new year when things settle down...
Old Dec 6, 2007 | 01:27 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
That pic actually helps. Will let you know if i run into any more trouble.
Why did you have to shorten the actuating rod? Will have to do the same? Im using the stock setup for everything. I will probably purchase a new stock clutch disc, but thats about it. The tranny, bell housing, B&M shifter, and clutch fork are from one car, the rest including hydraulics is from another car.
Both are 95 trans ams.
Old Dec 6, 2007 | 07:55 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Had to shorten the rod as it didn't provide the proper pedal height.
Don't use a stock clutch disc they don't hold much power over 300hp. I use the McLeod 7500rpm friction disc (I think Mcleod 261871) it has kevlar on one side and organic onthe other; with an SLP pressure plate that is the same as a stock LT4 PP but with holes drilled in the friction surface for less mass and easier disengagement.
A lot of guys here http://www.camaroz28.com/forums/forumdisplay.php?f=44
use an Autozone LT1 clutch. They use the PP, chuck the friction disk and use the McLeod. This is the cheapest source for the Valeo PP.
BTW there is only 1 company, Valeo, that makes all the LT1 PP's. The LT4 one has aslightly higher clamp pressure than a stocker. From what I know, even Spec uses stock Valeo PP's and paints them blue/purple.
Old Dec 6, 2007 | 08:04 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I know Mcloed is the name for clutches, but nearing the price of the transmission (or more), i just cant afford it right now. The stocker discs were behing an LS1/LT1 so it should be alright in my car for regular driving.
Mcloed will have to wait till next winter...
Old Dec 7, 2007 | 12:52 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
The Mcleod disk was under $200... from Summit.
The PP you can get for $200 as well.
Old Dec 30, 2007 | 12:03 PM
Zedsled's Avatar
Car: 84 Z28
Engine: Modded 350ci.
hey,i'm still here.
most of the cars are mine....my dad just owns the 71trans am..the rest are mine.lol.
Old Dec 30, 2007 | 03:29 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Hey!
Nice to know youre on the board. Damn thats alot of nice cars.
I spoke with your dad through e-mail about the pedals and stuff for you 6spd install, and he gave me a couple pointers. I think ill be alright, im almost done the swap. Just waiting for a clutch now.
Old Feb 10, 2008 | 07:30 PM
Zedsled's Avatar
Car: 84 Z28
ah...now i get to go though an even bigger swap...i picked up an LS motor so i have to re-wire the whole engine bay.ha. after i did all that work to get rid of all electronics i get to undo what i did....well after i find an LSx wired car to take the computer and wiring harness from.
and i have to convert my trans to LS1 style,so new input shaft,bell housing and hydraulics.That will probably start next winter.
Old Feb 10, 2008 | 08:03 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
So youre gonna rebuild the tranny? I dont think its thats simple.
In any case, what are you doing with your old motor?
Old Feb 17, 2008 | 04:44 PM
Zedsled's Avatar
Car: 84 Z28
the trans needs re-building anyway so why not do the swap at the same time.D and D performance in the states(not the one in chesterville) has the peices to do the viper spec borg warner T-56 and the ls1 input shaft
I'm going to get the old motor gone over and my girlfriend wants to drop it into a car she's found online that we'd have to go pick up.
Old Feb 18, 2008 | 02:36 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Cool. Let me know how the Ls1 swap goes, id love to come have a look when its done. Im basically happy with my car as it is, just need to stiffen up the suspension and ill be set.
Old Feb 19, 2008 | 06:42 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Carb the LS1.... Do IT!
Old Feb 27, 2008 | 05:00 PM
Zedsled's Avatar
Car: 84 Z28
i'm gonna run my LS2<--notice the 2 not 1 with the fuel injection..i've found a collection of donor cars for sale so i'll pick one up and have the quite a few parts for sale after i take what i need to make my ls2 work.
probably even an LS1 long block.
oh by the way...this LS2 isnt stock :P
Old Feb 28, 2008 | 07:54 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If so, I may be interested in the LS1 long block.
Old Mar 4, 2008 | 07:40 AM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
i know a tech here in Ottawa, and he had a t-56 just sitting in his shop from a 95 z28. he also had a brand new ls1 there as well, not sure if its still there but i know the ls1 is there still. Also was at the wreckers in the summer and there was a i think a 96 z28 there and it was manual
Old Mar 13, 2008 | 06:53 PM
Zedsled's Avatar
Car: 84 Z28
doh..if only that car was a 98 or newer.
6speedIROC
16
Mar 15, 2023 08:33 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
someone972
Aug 30, 2015 12:52 AM
