Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
MAF vs MAP
Old Feb 4, 2009 | 08:40 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
MAF vs MAP
Any votes to which is better or preferred?
Old Feb 4, 2009 | 09:00 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: MAF vs MAP
I had good luck with my stock MAF setup even after changing the cam with no chip change from stock. The increase in airflow is measured and the computer will adjust..within reason.
A MAP setup from what I know is much more sensitive to any changes and will require a new tune/chip for max performance.
Old Feb 7, 2009 | 10:35 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Re: MAF vs MAP
I dropped in a map set up (90 engine) and like was just said it doesn't like major changes even some bolt ons come to think about it.
A couple less sensors..... so a little cheaper that way but most would say GM went backwards with that set up.
I mean just look at what the more current cars are using.
Old Feb 7, 2009 | 10:51 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: MAF vs MAP
To put it simply, GM had MAF from 85-89, then MAP from 90-93, then MAF for the rest of its Pony car v8's. (to 02)
Generally Map is best for boosted applications
Old Feb 8, 2009 | 08:40 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: MAF vs MAP
They both have strengths and weaknesses
MAF is better at adapting to bolt ons(without programming) since it measures the mass of incoming air and reacts to it. With MAP it doesnt measure actual air flow but have set parameters depending on how much vacuum the engine makes.Both systems depend on sensors which are basically the same in function.
MAP is better because of the faster processor and there are no restrictions given by a MAF since the MAF itself is the restriction.
Old Feb 8, 2009 | 04:23 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Re: MAF vs MAP
I prefer MAP personaly, also Sheldon the 94+ are both, MAP and MAF
Old Feb 26, 2009 | 05:36 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Re: MAF vs MAP
have to agree. MAF is a pain when it breaks and costs alot to improve air flow thru (eg: bigger MAF unit)
My other cars use MAF last one broke cost me $450 to replace
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
