Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
tuning
Old Mar 3, 2009 | 09:44 PM
goleafsgo143's Avatar
Car: 86 Iroc-Z
Engine: L98 350 TPI
Transmission: 700R-4
Axle/Gears: 3.23 Posi
tuning
who tunes thirdgens in the GTA? I installed a 350 tpi in my car and at about 4000 rpm or so it bogs, not sure why, id like to get it figured out. So basically i need someone around toronto who knows tpi and can help me out, if anyone knows let me know, thanks guys
Old Mar 5, 2009 | 12:52 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Re: tuning
- are you throwing any codes?
- did you upgrade from 305 tpi? or Carb? TBI?
- I would buy a fuel pressure guage and see what is happening at 4k
the system is injected so you are either failing too lean or way rich. If its not fuel starved than the system is killing your timing.
Tuning TPI can be an insightful experience I recall I lost about 700 rpms once when replacing my knock sensor by tightening it too much. Backed it off and got my rpms back.
Old Mar 6, 2009 | 08:09 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: tuning
Talk to hawk92Z-TDZ he does a lot of TPI tuning and is just north of Mississauga.
He is also on www.ccfbg.com as Hawk
Old Mar 14, 2009 | 09:44 AM
Car: 86 Iroc-Z
Engine: L98 350 TPI
Re: tuning
thanks for the info guys, I appreciate it. In the end i figured it out and wont need anyone.. was just my ignition module going bad.. the simplest things are usually the ones..
Old Mar 16, 2009 | 07:22 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: tuning
Very true,the lil things can come back and take a nasty bite out of you but if you ever do start modding and want to get the most bang out of your setup..Hawk is the way to go hands down.
Zell1luk
Sep 29, 2015 10:36 AM
