Selling my old 383/700r4 setup cheap $2500obo
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Time to get rid of some stuff.Anyone looking to buy a full complete motor and trans with some good parts then here is your chance.
Built by Straight line 2 performance:
86 350 truck block,4 bolt mains
eagle cast stroker kit 10.5:1 compression
powermaster mini starter
afr 195cc,65cc heads with afr 8019 spring upgrade
arp studs,head bolts etc
compcam xfi 280 cam and lifter kit and dbl roller timing chain
chrome timing cover
holley stealth ram stock unported.holley fuel rail kit.
stock tpi 48mm throttle body
fic 32lbs injectors
kirban 6547 afpr
brand new fbody oil pan,hv oil pump and pickup
hooker 2055 headers and hooker y pipe
march underdrive polished pulleys
stock water pump
140 amp chrome alternator
msd 6al,cap/rotor
ngk spark plugs
700R4 auto transmission with shift kit.2800 stall converter
Motor and trans have under 1000km.Motor does smoke on startup.Come with ecu and engine harness(minus the dual fan harness) and the moates ostrich 2 programmer and software.
Looking for $2500 obo,moving onto bigger and better lsx swap.
Call Regi for any questions.416-843-5126
Located in Scarborough
Motor is still in the car for now.
chrome timing cover
fic 32lbs injectors
kirban 6547 afpr
stock water pump
msd 6al,cap/rotor
ngk spark plugs
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Selling my old 383/700r4 setup cheap $2500obo
chrome timing cover
fic 32lbs injectors
kirban 6547 afpr
stock water pump
msd 6al,cap/rotor
ngk spark plugs
chrome timing cover
fic 32lbs injectors
kirban 6547 afpr
stock water pump
msd 6al,cap/rotor
ngk spark plugs
Engine: 2005 LQ4
Axle/Gears: 3:54
No I did not have the problem resolved with Straightline.I havent had the time to pull the motor and bring it to them for further inspection.Andy did come down to see it running and insisted it was my water pump that was knocking.Needless to say it wasnt that,Ive since then parked the car and lost all interest in that motor ...and with dealing with Straightline to have it fixed.The motor itself is still under 1yr warranty period,I do start it now and then as the knocking has quieted down some and no signs of metal shavings in the 3 oilchanges Ive done to make sure nothing in the bottom end is coming apart.
So Im selling the motor as is..mostly for the price of the heads and lil odds and ends.I dont want to have this thing sitting around after my lsx swap and the funds can surely help me with the swap in general.Im sure someone can easily fix the motor and use lots of parts on it.The hsr is in good shape..as is the pullies,headers,y pipe,heads,cam etc.And the ecu is already chipped and comes with all tuning software for the ostrich 2.
Engine: 2005 LQ4
Axle/Gears: 3:54
Yea that was the first thing I tried and wasnt the issue.
Car: '85 Z28
Let me know if you decide to sell the headers / y-pipe separately. I'm in Mississauga this week.
Chuck84TA
Aug 27, 2015 11:14 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
