350 Engines for sale.
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
I currently have 2 engines for sale if anyone is needing a small block engine.
1st is a rebuilt LT1 (second gen sbc) converted to carb (with the proper Chevrolet intake manifold not a sbc drilled out to fit..)
I rebuilt this engine with new rings, cam, crank and rod bearings. Cylinders were honed, crank was machined 10 thousands.
It has a CSR electric water pump, CRANE CAMS roller cam (196/206@.050" duration) comes with Lt1 Corvette exhaust manifolds.
i built this engine for an 87' Trans am I had.. unfortunately the floors were too rotted and I decided to scrap the car..
i had this engine laying in my storage and in June 2020 I installed it into my mustang drag car to make sure it runs well.
I went to TMP to test out the engine and my mustang as it was new to me.. and it ran 12:53 with manifolds and 750 Holley (and a different cam at that time) Still in car and can be heard and seen running.
I spent $3200 on building it. Parts and labour. I'm asking $2300. Engine has 0 Kms on it. Only been down the track twice..
2nd engine is a 1980 4 bolt main (010 casting) 350 with 882 heads. Has an Edelbrock torker single plane intake, crane energizer 480 lift cam. All new gaskets. Haven't run this engine yet since the new gaskets, but will install it in the mustang to make sure everything runs good and no leaks. Can be seen/heard running.
Car: 91 Trans Am GTA
Transmission: OD automatic
Axle/Gears: 2.73 LSD
Re: 350 Engines for sale.
Hi. I sold both of those. I have another engine that i just rebuilt, you can call me. 64722541zerosix
LFN AT U
Apr 1, 2004 11:57 PM
