Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
What the CFM........!!!!!!!!
Old Feb 8, 2002 | 06:32 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
I am need a new carb and I have checked with the local speed shops and it seems that everyone has different ideas as to what the CFM's it should be. I was told that the Q-jet is a stock 700cfm. If I was to get a Holley, that I should use a 600cfm, and then another shop would say that it should be 650cfm. AAAHHHH......!!!!! Which is it?
P.S. I don't have the feedback carb setup anymore. The owner before me butchered it
P.S.S. Would there be enough clearance with a spacer plate between the stock air cleaner and the hood?
Old Feb 10, 2002 | 02:05 AM
Eric2ndGen's Avatar
To determine the proper CFM required, you need to state your engine displacement and cam overlap.
For the record- Rochester Q-Jets will deliver anything from 650CFM to 780CFM depending on the secondary throttle bore size and how far the secondary throttle plates will open- what this means is that the 650CFM units have an issue with throttle plate opening and this can be adjusted to get a full 750CFM out of the carb. The 780CFM units were typically used on big block trucks and had a slightly larger throttle bore.
Old Feb 10, 2002 | 10:07 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Well,I guess I'll have to look into this a little more closely. I have a 305 and as far as the cam, I have no idea. Is there a way to check the overlap?
Old Feb 11, 2002 | 10:58 AM
Eric2ndGen's Avatar
Don't worry about it- a relatively stock 305 can't move enough air to worry about it anyways. Anything from 600cfm up to about 750cfm would work A-Ok as long as you have vacuum secondaries (i.e. not mechanical) on the carb (Q-Jet and some models of Holley- check before you buy). If you decide you want to go with a Holley, keep in mind that they're harder to set up for good low speed and idling properties and tend to use up more gas than Q-Jets at low engine speeds.
Old Feb 11, 2002 | 11:12 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
My mechanic recommended an Edelbrock, only because the Holley is a little trickier to set up. I guess I have a decision to make. I can get a remanufactured Holley 650 for $275, or a new one for $425 with the adapter plate. Thanks,I appreciate the info, it clears up some confusion.
Old Feb 18, 2002 | 01:50 AM
383 Smoka's Avatar
Get the Edelbrock 1405... Its a 600cfm and its sweet... Never had a problem with it and u can find them everywhere.. They have em at PartSource even for like 250 brand new...
Old Feb 18, 2002 | 06:13 PM
Stroked-Z's Avatar
Hey buddy. If you have a relatively stock 305, go with a Carter/Edelbrock. 600 cfm is the max i would do.
Very fool-proof carb.
As far as performance issues, stick with a Holley. More parts readily available, easier to work on & generally in my opnion a much better carb. Good Luck....
Post engine specs for a more detailed reply
Old Feb 18, 2002 | 11:17 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Thanks for the info. My 305 is relatively stock, minus the feedback carb and distributor. I plan on some upgrades in the near future. I would like to get a few more ponies out of it. I plan on putting an Accel supercoil, cap and wires, TranGo shift kit PN #700,a K&N airfilter system and someday, when I can get the money together, a set of Hedman headers. Until then I must get a carb.The carb is toast. It was an old one that my mechanic had. He rebuilt it,but it still isn't right.
Old Feb 19, 2002 | 08:40 AM
Stroked-Z's Avatar
Definetly go with the 600 then. It will be good for you and will be even better when you open up that exhaust some.
Good Luck.
