cranes(gold series) or compcams(pro magnum) 1.6 roller rockers...
Old Apr 15, 2002 | 06:33 PM
Ivan383's Avatar
Anyone using cranes(gold race series) or comp cams(pro magnum)1.6 roller rockers? If so which ones work well? I will be installing 1.6rr on my 383 tpi(with LT4 hotcam).
Old Apr 15, 2002 | 07:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you have got the room under the valve covers use Harlan Sharp, the inventor of the roller rocker, about $180 from Summit.
Old Apr 15, 2002 | 10:33 PM
360Iroc's Avatar
PRO MAGNUMS worked great for me, love them using them on my other motor too in the process of being built...
Old Apr 16, 2002 | 10:42 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
those crane golds are too damn over-priced
Old Apr 16, 2002 | 11:01 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
<----poor ****
i'm using CraneCams 1.6 Energizers $140 from local speed shop
Old Apr 16, 2002 | 01:00 PM
TBurke's Avatar
I got the Crane energizer aluminums. I actually cracked 1 but replaced it before it could do any real damage. Comps are expensive but they are steel. If you have the bucks go with Comps.
Old Apr 16, 2002 | 01:13 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have Crane Golds and they are noisey as he11. Granted they were used on another engine before this one, but I still want them off of my engine as soon as I get enough money to buy Comp Pro Magnums. Keep in mind that the AL ones don't last as long and they are not as strong as the stainless Comp Pro Magnums.... The only downside to the Pro Mags is that you have to clearance the valve covers a bit if you use stock ones. Otherwise they are the best rockers out there, short of shaft mount ones.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
alpine247
Sep 16, 2015 05:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
