Vacuum Gurus needed...
Old Apr 13, 2002 | 10:18 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
Guys,
I just got in from about 11 hrs of fittle F'in around with me car. Yes I am pathetic I know! Got my new tach with shift light installed, new hypertech coil/distributer and rotor. Man what a difference in the startups. I then started looking for my mysterious oil leak again. I for some reason think it is due to too much crank pressure for some reason. I have been reading as much as possible on vacuum systems to help in situations like these. I decided to pull the drivers side pvc to see how much it was pulling. Well it was seemed pretty adiquete. I then moved to the passengers side and there was nothing! Nothing at all! I thought what the heck! I then took the vacuum line off that goes up to the purge canister located right below passengers side vacuum line on the TB. The air was wistling through that one. It was a VERY strong pull even at idle. So I thought that maybe the other hose had an obstruction. I pulled the line off the throttle body and still at that point there was nearly no vacuum at all. I thought maybe if I hand rev the engine it will increase as more air passes throught the TB. I performed a few revs and still nothing! I decided to pull the TB off and investigate the passageways. After taking the TB off I blew threw the upper hole and air went freely throught the passage I investigated further and found that the air travels up to the top of the TB just under the Tune Port cover. From there it travels down through the hole that subsequently is blocked 3/4 of the way by the Freakin P.O.S. Air foil *nut*. If you have one you know what I am talking about. Still air could get through there. The air then travels out from around the air foil into the SR. This path must have considerably less vacuum that the lower port. I began thinking that perhaps I could switch the two lines. That might give me the added vacuum at high RPM and keep the engine oil from leaking. I assembled the entire TB after first cleaning the IAC pin, etc. (idles much better now).
Got the vacuum lines switched and HOLY cow. That baby is really drawing now! I could hardly pull the dip stick out. And when I did I could hear the air wistling down through the opening. Surely this is more than enough vacuum, but am I hurting anything by having too much vacuum on the crank? I would imagine its doing the same as an aftermarket crank case air pump would do. The car seems to rev much, much quicker now. I want to hear you guy's thoughts on the idea. Thanks a million.
Old Apr 14, 2002 | 07:59 AM
ski_dwn_it's Avatar
TTT
Old Apr 14, 2002 | 08:25 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Vacuum Gurus needed...
There's not supposed to be engine vacuum on that side. That's where the air goes into the crankcase that the PCV valve is pulling out. P)ositive C)rankcase V)entilation.
Mine just has a small breather on that side.
Old Apr 14, 2002 | 09:14 AM
ski_dwn_it's Avatar
Will it hurt having it on that side? With the stock set-up it runs to the TB too. There is a very slight draw in the direction from the breather to the TB? I have always read that you should have a vacuum draw on the crank keep air out, not in. I am a bit confused now. Could someone clear this up for us. Thanks
Old Apr 16, 2002 | 01:43 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yeah, that passage in the TB that you traced is a breather passage and it is just there to let crankcase gas go into the engine and not the atmosphere. The PCV valve basically meters the amount of vacuum that the engine pulls on the crankcase and that is why that side has some vacuum supplied to it and none is supplied to the passenger side valve cover.
Hmmm.... not sure what kind of damage you might do with those switched..... You will definately get the inside of the intake full of oil in a hurry and that added oil in the intake charge may cause problems with getting the AF ratio dialed in since you are pumping extra HCs into the engine....
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
