Injector ohm reading?
Old Apr 15, 2002 | 07:01 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
I am about to install my injectors back on to my engine. I wanna see if any of them have gone bad (and caused the failure of my engine last year). How do you test them? What readings should you get?
Old Apr 15, 2002 | 07:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
IIRC, should be 16-18ohms, but that won't tell you much about their flow capabilities, or lack there of...since they're out, might be a good time to send them to Rich@cruzinperformance.com and have the tested and flowmatched. Price is right around a C-note, or talk to him about some Accels.
Old Apr 15, 2002 | 07:44 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If you suspect a bad injector it would be a good idea to send the set to Rich at Cruzin Performance (link on my site). He reconditions and flow tests them for $10/injector. Plus he is in MI so shouldn't be a high shipping charge for you.
Though he usually has 48hr turnaround, he will be away from 17th-21st. I'm sending him a set (including the cold start one) later this week if things work out with my schedule.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
