HSR
Old Apr 19, 2002 | 08:59 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
HSR
Has any one though of closing off the bottom (to the lifter valley) then opening up the space under the runners so there is an air space/flow under the runners? Like the Edelbrock “Air Gap” intakes. From the pictures in the other post it looks like this would be the way to go with this intake.
Old Apr 19, 2002 | 09:15 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Fabbing up a valley cover would be easier and cheaper and have the same effect for the most part. But yes if someone wanted, a plate could be welded and machined, then mill open the sides. Lot a work really. cheers, Bob
Old Apr 19, 2002 | 11:15 AM
cfabe's Avatar
On the pics of the bottom It looks like there are 4 posts in the casting that would be ideal to drill and tap for small bolts to hold a splash guard in place. You'd still have some leakage around the edges but it should bring it back to the level of oil-heat-absorbtion-resistance that you have on other intakes.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
