why is it ideling so high?
Old Apr 20, 2002 | 04:49 PM
1bad350's Avatar
why does my car idle at between 1500 and 2000 RPM,s? usually its right on 1500 but somtimes it surges up to 2000 rpms. its really getting on my nerves and is hell on my breaks and gas millage in town
Old Apr 20, 2002 | 06:18 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Check for vacuum hose leaks or opens.
Pull the IAC and clean the pintel and bore with TB cleaner; clean the TB bore and throttle plates ONLY with TB cleaner. Then reset the base idle (method on my site) and the TPS base idle value (if adjustable).
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
