19lb/hr or 22lb/hr???
Old Apr 23, 2002 | 09:00 PM
formcam's Avatar
I have a 1989 5.0 with a 5-speed. I need fuel injectors but the car has 136,000 miles on It. I also believe that the motor in my car could blow at any moment and I will not be rebuilding the 305. The 350 will be the mill of choice. I believe that the 305 in the 1989 with 2 cats had five or 10 hp less then the 350.
CAN I GET A WAY WITH THE 350 INJECTORS?
Could I play with the fuel pressure to make it work? Has anyone done this?
Old Apr 23, 2002 | 10:03 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
With the mods on the IROC I"m currently running Corvette 22# injectors.
You can run them on a stock LB9 by reducing the fuel pressure; not the best way to go but ok if only temp. In that case get a set of used injectors and have Rich recondition and flow test them for $80/set.
If you're going to install a stock L98, just have your LB9 19# injectors reconditioned and run them at higher fuel pressure.
Old Apr 23, 2002 | 11:12 PM
89Irocker's Avatar
I am running 24lb injectors in my LB9 305 right now but I have a custom prom, I wouldn't suggest anything bigger than 22's though cause my fuel economy sucks! 14mpg in town.
Old Apr 24, 2002 | 02:26 AM
Bort62's Avatar
You can easily get away with 22, or even 24 lb injectors on your Lb9, but Your going to need to change the injector constand in the PROM and perhaps wankle with the fuel pressure a bit to get it right.
Turning down the pressure whilst leaving the injector constant at 19# is a band-aid. Might as well get the PROM burning equipment now, especially if you have L98 swap plans in the future.
Old Apr 25, 2002 | 08:31 PM
formcam's Avatar
This question is for the people using the 22LB/hr on their 305s.
Is the Block Learn on your fuel trim showing rich or lean?
Old Apr 25, 2002 | 10:43 PM
Swapmaster's Avatar
Watch the Block Learn, the Integer will recenter itself when the
Block Learn stabalizes. Seeing what cell the Block Learn is in will
tell if you are good or not. If it is rich the BL will drop below 128.
Old Apr 26, 2002 | 07:31 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
no, my BLMs and mileage are fine, it's just a matter of setting one number in the chip.
dbrochard
Feb 14, 2016 09:04 AM
cubangt
Mar 1, 2014 06:10 AM
Jim85IROC
Oct 18, 2006 11:24 PM
WheelsUp84z
Oct 1, 2006 05:21 PM
ryn28
Jan 20, 2002 04:19 PM
