Need help with vacuum canister line routing...
Old Apr 23, 2002 | 09:36 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I have my vacuum canister hooked up right now and everything seems to be running good but I want to double check to make 100% sure that I have all the vacuum lines going to the right place(s). If anyhow could post pics and/or describe where the vacuum lines should be going I'd appreciate it.
Old Apr 24, 2002 | 02:51 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
The vacuum line from the vapor canister goes to a T-connection under the plenum. From there, one of the lines goes to the EGR solenoid while the other goes to a vacuum port underneath the throttle body.
Old Apr 24, 2002 | 05:41 PM
Arawn's Avatar
On my TA there's also another slightly larger (7/32) hose going directly to the throttle body.
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
