SES codes, what can I do with these mods?
Old Apr 26, 2002 | 08:08 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Ok so I pulled the codes off my ECM and found that I am getting a code 32 and a code 44.
Code 32 is faulty Baormetric pressure sensor
Code 44 is a Lean O2 sensor reading
I do have an AFPR, will I be able to at least curb the lean problem if I were to adjust the fuel pressure or not?
Code 32 I am at a loss of how to fix it. Any ideas?
Motor: 350 .030 over 10.3:1 on stock heads and TPI, .495/.502 218*/224* 110*LSA, AFPR, stock 22# injectors, TCI 2400 stall on the stock 700R4, SLP 1 3/4" headers, replacement stock fuel pump feeding this thing.
Old Apr 27, 2002 | 02:06 PM
Swapmaster's Avatar
Check for vacumm leak at the MAP sensor, if there is no vacuum
leak, replace the MAP sensor and your code 44 will probably go
away also.
db057
Jan 10, 2020 08:55 PM
BumpaD82
Feb 26, 2016 02:57 PM
Shane87irocz
Sep 22, 2015 06:21 PM
lethaldomestics
Sep 21, 2015 01:18 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
