i need help with tpi runners
Old Apr 28, 2002 | 03:47 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
is it hard to remove the runners? can i do it without having to take or move other things out that are in the way?
Old Apr 28, 2002 | 09:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's a few hidden bolts,...need to be reached from the opposite side of the runner...they are "inside", not viewable from the side you're removing.
Other than that, the plenum, TV cable, cruise, throttle cable backet comes off, and a few fittings under the plenum. Not much to it, just look it all over before you take it apart...may be a good idea to label things for re-assembley...assuming your memory is like mine
Old Apr 28, 2002 | 09:57 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Don't bang on or pry against the runners. You'd be amazed at how easily they dent.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
