Does TPI require certain distributor
Old Apr 28, 2002 | 10:56 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Does TPI require a certain distributor, I know I need a diff. style to work with the stealth ram I ordered, would this one work.
http://store.summitracing.com/partdetail.asp?part=923
Does anyone have a part number of one I should get?
Old Apr 29, 2002 | 07:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That won't work. Read the description! That distributer is designed to work with motors that gets its timing from a crank sensor. MSD makes a late-model HEI distributer without a vacuum advance, but I don't have the part number handy. If you open the summit catalog, it'll be listed separately from the other MSD distributers.
Old Apr 29, 2002 | 07:51 AM
Jim85IROC's Avatar
more info...
For the stealth ram, you're going to need to use an HEI distributer with an externally mounted coil. That MSD I talked about above is like that, but so are all f-body distributers from 88 and up. It would be a lot cheaper to just snag a used distributer from a late model Chevy. I think all the trucks and vans used the same type, so getting one out of a bone yard should be pretty easy.
Old Apr 29, 2002 | 08:59 AM
86FyrBrd's Avatar
thanx man, I appreciate the help, I think my last question will be about the EGR, but I'll post that later.
Old Apr 29, 2002 | 03:38 PM
86IROC305's Avatar
Any 88+ TBI/TPI distributor would prob. work, I got mine from a 88 TBI Camaro and it works fine. The wiring is the exact same colors, so it's just cut and splice. If you need the pigtails for the ign. mod. , they are an easy find also. Almost any TBI s-10/TBI truck/F-body will have them (that is if someone hasn't hacked the wiring harness to pieces). It only took me about 30min to swap from my HEI to the external coil one.
-Joe
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
