i broke something and i need help to figure out what it is
Old May 2, 2002 | 09:37 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i took off my plenum and was taking the bolt off on the back of the passanger side runner and this small plastic wire or cable was in the way so i went to go move it and the freakin thing snapped in half. it connects to the throttle body and is on the bottom corner on the driver side. it runs from there to between the fuel rails and then back by the firewall. i'm not sure where it actually goes, but i need to know what it is and if i can fix it or do i have to buy a new one and where can i get it. sorry the description isn't too clear, but it's the best i can do. thanks
Old May 2, 2002 | 09:45 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
from what you said it sounds like you broke a plastic vacume tube. you can go to the auto store and buy a small section of rubber vacum line to slide over the two ends make sure it fits snug to give a good seal.
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
BBSDesigns
Sep 22, 2015 03:08 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
87hellbird
Sep 14, 2015 05:08 PM
