Fixed head gasket. Now she idles at 1300rmp.
Old May 3, 2002 | 05:02 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I finished my head gasket swap. While I had the heads off I swaped the valve springs. Started it (w/ just heaaders), adjusted vales, set timing, tried messing w/ the fuel presure. Couldn't get the idle below 1400.
I don' think I have a vacuum leak. At least non thats visable. What could make the idle go up 600rpm w/ no obvious changes?
Thanks in advance.
Old May 3, 2002 | 05:12 PM
tpi_roc's Avatar
vacuum leak, its the most likely, if you can't SEE one, spray a bottle of water around all the vacuum lines and if the car stumbles you found the vacinity....
Another possibility is the TPS/IAC needs to be reset, coulda bumped it taking the intake off
Old May 3, 2002 | 05:41 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Thanks a lot. I'll try it tonight.
theshackle
Sep 17, 2020 08:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
