Doug Flynn...what kind of low/midrange power does the Stealth Ram make???
I was talking to a guy from AFR trying to get a head/cam recommendation. He didn't know of the Stealth Ram at all. He said that it's really important to know when the intake wakes up. I saw the post on the other site with those dyno numbers, but it doesn't show anything below 3400 RPM. So I was wondering if you knew what the power was like below that point. Thanks in advance.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Considering how much it gives up to TPI at 3,500, I'd say it's going to give up a LOT at rpms below that... but (there's always a but), that was on a bone stock L98. A stock L98 is such a horrible miss-match for a stealth ram, that I wouldn't expect any low end power. The right heads (such as AFRs), cam and headers should allow it to get that midrange power back.
Well, I found this on the Holley website.
http://www.holley.com/HiOctn/ProdLin...AMSM/5954.html
This looks darn close to the Stealth Ram, if it isn't the same casting. It says operating range 2800-7000 RPM. Should I go off of this for when I talk to the AFR guy again? Thanks.
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
novaderrik
Aug 10, 2015 12:44 PM
