Firebird would not start tonight
Old May 3, 2002 | 05:48 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
It ran fine on the way to work this morning, I parked it in the lot, and it sat there 'till 5:00 o'clock.
When I tried to start it after work It acted like the starter wasn't getting power.
Are there any fuses or fusable links I should check?
Old May 7, 2002 | 05:34 PM
Problem solved, the little contacts inside the ignition lock wore down so that there was no contact with the key.
I wired a resistor inline untill I can fix it right.
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
