prom that doesn't use the 9th injector?
Old May 3, 2002 | 10:17 PM
mckenzie's Avatar
hello, i have a 86 iroc with a 305tpi. i have heard of other people using a later prom that only uses 8 injectors. i heard that it adds extra fuel at start up. anybody else using this newer prom for the 9 inj. setup? anybody know the part number? thanks, tom
Old May 3, 2002 | 11:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not sure of the part number, but you'd want to look for one from an '89...MAF, with no CSI. After '89, TPI's were SD, and used no MAF and a different ECM.
You do have the 165 ECM?
Old May 4, 2002 | 01:40 PM
Desert86Roc's Avatar
There is not a version you can buy off the shelf...this is something that you could custom program for.
I used the ARAP code as a base for my Eprom, and did the injector delete of the hardware. If you engine is in good shape, and in tune...you should see some significant gains from programming your own chip, even on the stock motor.
Old May 8, 2002 | 03:28 AM
Arawn's Avatar
Is eliminating the 9th injector that easy? Just disabled it in the prom and remove the hardware? And is there any good reason for doing this?
Old May 8, 2002 | 08:58 PM
Omar's Avatar
If you do find a prom from an 89 TPI 305 AT, make sure it has the VATS deleted also.
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
djmarch
Aug 10, 2015 08:42 AM
