Compatible TPI Parts
Old May 7, 2002 | 05:13 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Will runners from an 1985 305 mate up to later
TPI intake manifolds ie, 1988-1992?
Will fuel injectors from 1990-1992 350 TPI's
fit a 1985 fuel rail?
Lastly, are there any aftermarket intake manifolds
that have the center bolt holes already drilled to fit both early and later heads?
The situation is--I have a built 355 (1972 4 bolt main block) with pre '87 heads, and a complete 1985 TPI unit, so Im trying to figure out the best route to go running speed density.
Thanks in advance!
Matt
Old May 7, 2002 | 11:10 AM
tpi_roc's Avatar
Re: Compatible TPI Parts
Thanks in advance!
Matt
Yes 85 runners will BOLT to a 92 base, but they have a hole in them for the 9th injector that SD doesn't have. So I'd get the right runners.
Yes fuel injectors are fairly universal, you can even run ford SVO injectors.
I have the same situation, just block a few things and you're good to go. I dont know about an aftermarket base being drilled for both, but it certainly isn't hard to operate a drill.
Old May 8, 2002 | 12:48 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Only difference in pre 87 and 87-92 heads are the 2 center bolts on each side. 87-92 heads, the center holes are almost straight up. Pre 87 the center holes are perpendicular to flanges. Notch out the holes in later intakes to mount to early heads and vice-versa.
Old May 8, 2002 | 04:01 AM
Matt_Ky's Avatar
Thanks guys. I guess I will stay with an '85 or '86 lower intake manifold if I can locate a decent one. I have a 730 ECM. I also have a complete 85 MAF wiring harness and ECM, so I think I will have someone such as Chevythunder redo the harness for speed density.
I need to find out where to tap a hole for the MAP sensor. I also need to find a knock sensor for a 350. I will not be running EGR so I need to figure that out.
I need to take the Edelbrock RPM camshaft out (originally was going to be a carb setup) and decide on a camshaft (hydraulic flat tappet) more streetable and computer friendly.
Lastly, do you know if GM part #5235302 is fuel injectors from a 350 TPI engine 1987 or 1988?
Thanks again for your input!
Matt
Old May 8, 2002 | 07:04 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
5235302 is a GM casting # that is serviced by part# 17111961, this is for 87-88 F & Y bodies. BTW, they are Bosch injectors.
Old May 8, 2002 | 05:49 PM
Matt_Ky's Avatar
Thanks for the info on the fuel injectors.
Will they work on a 1985 TPI unit?
Are they 22 lb/hr?
Matt
Old May 8, 2002 | 05:57 PM
Bort62's Avatar
I know where a 85 intake is located, PM or Email me if your interested I can point you at the guy.
peace.
Old May 8, 2002 | 07:06 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Go with an after market intake, the edelbrock tpi high flow manifold is drilled to fit both styles heads. So if your going to build up that 355 I would do that. Any port it out if you want more air flow.
Old May 9, 2002 | 02:33 AM
Matt_Ky's Avatar
Bort62,
Yes, I would be interested in the '85 intake manifold. Do you have the guy's email or phone number? Where is he located?
Matt
Caspar
Jun 19, 2016 11:19 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
