Smog Pump Removal Question
Old May 11, 2002 | 10:14 PM
bandit454's Avatar
I have a 1989 Formula Firebird with a 305 TPI. I have read all the questions on the smog pump removal but I haven't found a answer to mine. I have the dual cat system and I have 2 connectors that go to the switch valve, the computer fires these solonoids to change where AIR goes. Do I just leave these unplugged and if so these do not affect computer??? From what I see it doesn't give a input to computer, just ECM gives output to it. Thanks for the help.
Old May 12, 2002 | 10:58 AM
bandit454's Avatar
Anybody???
Anybody got any ideas???? Please help befor I have to put my valve covers back on.....Thanks.
Old May 12, 2002 | 11:03 AM
360Iroc's Avatar
i let mine plug in, any nothing changed..if that helps any
Old May 13, 2002 | 09:25 AM
MNformula350's Avatar
Take it all off!!
I had mine unplugged for a few years and passed emissions twice,like that and with a hollowed out converter.
I say you should just remove the smog pump etc.... it really cleans up under the hood.
there is a tech article on this site on how to reroute the belt after removing the smog pump.
Old May 13, 2002 | 11:33 AM
bandit454's Avatar
I heard also you need to hollow out cat. convertor or it will stop up if you take the smog pump off, is this true, we don't have the smog test here but just wondering...Thanks for the reply Dave84Bird
Old May 13, 2002 | 11:47 AM
89BlueTA's Avatar
You can just disconnect them, it will not affect anything.
nick
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
