Testing fuel pump operation from ALDL
Old May 12, 2002 | 06:41 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I cant remember how to turn on the fuel pump with the car not running from the ALDL.
I think vader said that you have to ground the G pin with the ignition ON or something. I cant remember for sure though.
Thanks for any help.
Old May 13, 2002 | 09:55 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I know that someone knows this (vader) and my fuel pump barely made it from florida to NY. now I have to drive to hartford and I really need to make sure the fuel pump will make it.
I have already tested the relay and oil pressure switch but the dang fuel pump sounds sick during the 2 second prime before I start the car. I really have alot of Idle and mixture problems that i think are the result of the pump and all I need to do is test it.
Thanks again for any insight on how to make the fuel pump run with the engine off.
Old May 13, 2002 | 01:01 PM
Justin Moore's Avatar
Car: 1986 Z28
It's been a couple of months since I did this but I am pretty sure you need to supply 12V to the terminal G.
Old May 13, 2002 | 02:31 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
cool, so I could just take it from the fuse block or no?
Old May 13, 2002 | 02:35 PM
Car: 1986 Z28
That's what I did..
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
