HELP! Throttle lever on the TB won't return completely....
Old May 13, 2002 | 08:08 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I was driving my car today and everything was fine.. until I left from lunch. I got in my car and started it and noticed it was idling high. I figured it would idle down but it never did. I stopped the car and put it in park and it was idling up around 1500 rpms in park. I popped the hood and looked at the throttle lever and it was sitting about 1/8-1/4 inch from the throttle stop. If I tap the throttle really fast it will snap all the way back to the throttle stop but if I just gradually ease into the throttle and then let off, it won't snap back all the way and idles way too high. I never did take a look at the throttle spring previously but the throttle spring as it sits now is very loose and I think this is what my problem is. Can someone verify that the spring is supposed to be wound tight.
If it is indeed the throttle spring like I think it is, what can I do about it?? Can the throttle lever and spring be replaced or do I have to buy a new throttle body? If the throttle lever and spring can be replaced does anyone have a part number and do I have to go through GM? Any help would be greatly appreciated.
Old May 13, 2002 | 08:59 PM
camaro6spd's Avatar
the TB wear and creat gooves....my old one did that....
Old May 13, 2002 | 09:08 PM
Creates grooves where? I've already cleaned the inside of the TB and the blades and the walls feel smooth.
Old May 14, 2002 | 12:59 PM
camaro6spd's Avatar
The shaft that the TB blades attach too, it wears...there is a guy that puts in roller bearings and bores out the TB to 52mm for 190....i was gonna do it but i got another car.....the 88.
Old May 14, 2002 | 09:21 PM
More info please. Phone number, email address?? Anything. Thanks.
maroe624
Apr 16, 2017 08:29 AM
Matt86IROC
Sep 7, 2015 06:30 PM
TheTraut88
Sep 7, 2015 05:22 PM
L98GTA87
Aug 25, 2015 02:23 PM
justin57
Aug 20, 2015 07:05 PM
