injector size on this modded 305,what do u other modded 305's use
Old May 14, 2002 | 03:14 PM
BT305TA's Avatar
I need to know what size injectors i should be using on my 305.Right now i have the stock 19# injectors on it but I need the fuel pressure to be at 52 to keep it running good.Should i use 350 injectors or is that too much fuel for it.I need to know because i am having a custom chip burned.
Old May 14, 2002 | 08:12 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
what all have you done?
if you are getting a custom chip tell them you have the stock injectors and they should open up the pulsewidths so that you can put more fuel into your engine.
i almost dipped into the 13's on the stock injectors and stock fuel pressure setting on my 305.
Andrew
Old May 14, 2002 | 09:10 PM
BT305TA's Avatar
I have a camshaft 210 220 .480 lift world product heads,ported intake,headers,high flow cat ect.
Old May 14, 2002 | 10:25 PM
bigals87z28's Avatar
Car: Check The Sig
this is just me but i would get the #22 injectors and an afpr... set it to 50-52... you could do it that way..... i dunno a whole lot about what chips can do... so i just go with stuff i know about... hope it made sence... aight peace
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
knight72
Aug 10, 2015 09:32 PM
