5.0L 305 LB9 comparison in Years
Old May 14, 2002 | 08:09 PM
maverick544's Avatar
I was looking a the Third Generation (1982 - 1992) Technical Data, and noticed that on my 89 Auto 305 TPI, the hp is 295 than 90 it goes up too 210hp on the same engine and tranny, whats up with dat!
Old May 14, 2002 | 08:56 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Re: 5.0L 305 LB9 comparison in Years
Originally posted by maverick544
Guy's I know I cant spell
bwahahahahaahaha, please say you did that on purpose. ROFLMAO
Old May 14, 2002 | 08:58 PM
Ed Maher's Avatar
Car: 04 GTO
And the difference in the engine is the cams. Your 89 would have what's known as the peanut cam, complete junk. The 90-92 TPI cars all come with the L98 cam. The only way to get a good cam in the 87-89 305s was with the 5 spd and G92.
Old May 14, 2002 | 10:08 PM
bigals87z28's Avatar
Car: Check The Sig
i thought that the increase was due going from MAF to SD? i heard it increased the output 5hp.... dunno about that?aight peace
Old May 14, 2002 | 11:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
First its not 295 HP, its 195. The difference was the cam changes. The compression is all 9.3:1 for all years of 305 TPI, as far as I have seen. 89 MAF and 90-92 SD 305 TPI 5-speed with G92 is all rated at 230 HP, so the MAF -> SD switch gained nothing there. The 350's gained 5 HP from a piston change that increased compression about .5 points, from 9.3:1 to 9.75:1 or so.
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
Thornburg
Aug 25, 2015 01:46 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
kyleb24
Aug 15, 2015 08:24 AM
