5.7TPI things to look for..
Old May 15, 2002 | 03:26 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Hey guys
Im checking out a 5.7L IROC
Is there anything i should look for, besides what I know what ot look for in a TBI engine..
anything really different?
Old May 15, 2002 | 05:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
this is my 5.7 out of my 88 IROC. this is an old pic but will show you the basics. to look at both 5.0 & 5.7 engines they are visually the same. 5.7 auto's has the square shifter. they also have the 5500 rpm redline opposed to the 5.0's 5000. one way of telling is by running the vin to be sure. another would be to look on the drivers side towards the rear of the block. look on the top(right by the head) and it is stamped 5.0L or 5.7L. that's a bitch to get to though.
Old May 15, 2002 | 09:19 PM
BOTTLEDZ28's Avatar
Transmission: A4
sometimes dealers and privite sellers say there is a 350 in the car and its really a 305. take a look at the engine compartment real well, if you see big scrathces in the carpartment on the paint then chances are the engine has been pulled. look for bolts that dont look the same as others on the same parts. just take a long time to look at the engine and entire car. take it to your mechanic and have him put it on the lift and check out the underside. look for rust and missing parts. look at the starter. if it has a small solieniod then chances are it is a 305 and if the solieniod is big then it is a 350. not sure if it mattered on that year though. look for factory spot welds on the radiator support and wherever there is a weld. see if it is factory or body shop quality.
Old May 17, 2002 | 11:05 AM
tpi_roc's Avatar
How sure are you?
And the vin/shifter aren't such good ways to tell considering how easy the shifter is to change, (not to mention my friend has a V6 with a square shifter) the vin doesn't mean a thing if the engine was swapped.
Old May 17, 2002 | 11:24 AM
Car: 1988 IROC-Z
i know that vin, shifter, and redline dont mean much if the engine has been swapped out. another would be to pull the valve cover off and check the head casting #'s. that's why i suggested the PITA method to take a look back there. just in case some one swapped out the engine, tpi_roc .
Old May 17, 2002 | 11:41 AM
Morley's Avatar
Not always true. My '85 with a 305 TPI has a 5500 red line.
~M~
Old May 17, 2002 | 12:03 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
305s & 350's both had square shift *****, not that it would tell you anything on a 10+ year old car that could very well be monkeyed with. The square **** goes with the leather wrapped steering wheel found on most Z-28s & Irocs.
Old May 17, 2002 | 12:18 PM
tpi_roc's Avatar
Please disregaurd most of mysticals ways of telling if its a 350
jk
If you're fairly positive the car is absolutely stock, an easy area to pull numbers from is the injectors, then refference those to see what lb/hr they are, which will tell you if its a 305/350. Other than that pulling block numbers is about the only way.
Bubbajones_ya
Aug 31, 2015 12:02 PM
injdinjn
Aug 28, 2015 12:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
