Will this set-up feed a 383 fairly well
Old May 16, 2002 | 01:12 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I called up and cancelled my order for my Stealth ram today, my 350 blew and I need to save as much money as possible, and dont have time to do a swap that includes changing stuff around likethe stealth ram would, I am getting my 350 rebuilt to a 383 stroker. I have everything except the bigmouth listed below, and the big mouth is on the way. Will this feed a 383 to make fairly decent power, how high in the 300's or how low in the 400's do you think this set-up is good for.
Ported & Siamesed Plenum.
Slp Siamese Runners.
TPIS Big Mouth Base.
Suncoast Ram Air.
Old May 16, 2002 | 03:52 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
what id do is get a lt1 intake from john millican it cost the same for that as that big mouth u jus ordered id sent it back i jus put a 383 in my car and with the lt1 intake it rocks i ran a best of 12.4 @110 with me wheel hopping off the line i the torqe is still there i was pulling 1.6 60 fts i love the set up its an easy install ive had it on since march this is my daily driver ive had no problems with it at all later
Old May 16, 2002 | 04:32 PM
86FyrBrd's Avatar
Wouldnt a TPI setup that is pretty much totally modified to flow more air like mine (ported pleum, bigger runners, bigger manifold) flow almost as much or equally as much as the LT1 intake.
I'd atleast be around mid 12's too rite? or should be?
Old May 16, 2002 | 10:31 PM
Car: 92 camaro
Engine: 383 stroker
here is the way i understand it you wont get the tpi to flow like the lt1 its not so much how big your base and runners are but the length of the runners tpi jus doesnt do much over 5000 rpm i was a little none beliveing of this until i swapped to the lt1 with the tpi i rarely hit my rev limiter "6000" but now with the lt1 it took me a little while to get use to how fast 6000 comes now thier for a while i was always hitting the rev limiter it comes so quick now i had a completely upgraded tpi im very happy with the lt1 it gives you alot more potential for future mods if you think about it have you ever seen a after market lt1 intake? i havent there no need for it if im wrong im sure ill be corected jus my.02 worth later:lala: :hail:
LT1Formula
Oct 8, 2015 08:34 PM
FormulasOnly
Oct 2, 2015 05:52 PM
