both fans on at the same time.
Old May 16, 2002 | 11:17 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Ok my cooling fans come on at the same time, SOMETIMES. I have not yet found a reason for the intermittent event. It has done this for a while and i only noticed the damage at the track the other day, when neither fan would come on. The orange feed wire had burnt up. Sometimes only the left fan (looking from the nose) turns on. The problem is this when both fans engage it is SMOKING my orange feed wire. This is the wire with a fusible link on it over by the battery. This wire get s hot to the point of burn through. I really need to get this under control as, i am not going to gut the wire harness and replace for a fault the should not be happening. Please help.
SHAGGY"puzzled but staying cool"IROC
__________________
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.1@ 100.01 MPH w/t-5, installed my 3.27 B/W. 244 HP/347 FTLBS ON THE GROUND!!! Not bad for just bolt-ons.
so much to do , so little money
Old May 17, 2002 | 09:27 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
not that you'll do it but i control both fans via a switch under my steering column
Old May 17, 2002 | 07:00 PM
Jza's Avatar
Jza
Re: both fans on at the same time.
Why don't you just pull out the fan harness and fix that on the bench? It's just that 6-prong connector and comes out with the secondary fan relay and the plugs to the fans.
Anyway it sure sounds like a couple wires are crossing somewhere. Hopefully it's in the "mini" fan harness and not before the 6-prong connector on the main engine harness.
sheachopper
Jul 31, 2019 11:27 AM
mattcanty
Oct 12, 2015 11:08 AM
bjpotter
Oct 4, 2015 07:48 PM
Fanatic1074
Oct 2, 2015 03:47 PM
3.8TransAM
Oct 1, 2015 07:47 PM
