What injectors should I use??
Old May 19, 2002 | 10:54 PM
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
I was wandering what size injectors a 1987 350 TPI motor has? I have herd both #19 and #22 injectors were used I have a few bad injectors in my car and I have a whole set of #19's. I have also herd that a set of #19 with increased fuel pressure work better than #22's. Any help would be appriciated.
Jeremy
READ THE FORUM RULES ABOUT ATTACHING PICTURES
Yellow 87 IROC-Z 350TPI
Mods:
Edelbrock T.E.S. and Y-pipe
Removed converter
Flowmaster Cat back
K&N filters
Removed air box baffles
Accel 8.8mm 300+ race wires
Eibach Sportline Springs
Prothain Poly bushing kit
PST poly trans mount
O.R.C. subframe connectors
14.49@94.55 in the 1/4
2.03 60'
9.28@74.33 1/8
Old May 19, 2002 | 11:20 PM
BenDoe91z28's Avatar
i think 19#s would be fine at a high pressure
Old May 20, 2002 | 07:53 AM
Z28DJP1987's Avatar
Go with the 22# FI which are standard with a 350 and save your
fuel pump with less pressure.
Old May 20, 2002 | 11:09 AM
tpi_roc's Avatar
22's!
Old May 21, 2002 | 07:12 AM
speedy3838's Avatar
Car: 85 iroc
Engine: 400 sb
Transmission: 350 turbo
what size injectors should I use and what kind off fuel pressure do I need for a 406?
Old May 21, 2002 | 09:30 AM
tpi_roc's Avatar
Fuel injector size is directly proportional to horse power and number of cylinders.
a shot in the dark I'd say you'd need to be around 26-28 but dont know without numbers
Old May 21, 2002 | 01:55 PM
BlazinOR's Avatar
I run 24 lb Accels with my 406, the BLM's are right on the money.............fuel pressure is just up slightly from stock.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
