TB Coolant Bypass Benifits?
Old May 21, 2002 | 06:55 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
What would be the benifits of bypassing the throttle body coolant?
Old May 21, 2002 | 07:08 PM
Wolfpack's Avatar
Car: 86 Iroc
I just did that mod to my car as well. If you noticed after running the TPI cars that the plenum and the rest of the intake system is hot enough to cook off of? The bypass is supposed to lower the temp of your intake system giving you a denser colder charge of air...meaning more power. Its prob not gonna be a noticible improvement but every bit helps
Old May 21, 2002 | 08:08 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Do a search. There's plenty of posts to look at about disconnecting the coolant.
Old May 22, 2002 | 07:54 PM
rondubbs's Avatar
benefits :
1) cleaner looking engine bay
2) .000001 hp increase
Old May 23, 2002 | 04:38 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Benefit: next time you take off the TB, you dont have to unhook any coolant hoses from it. It just cleans up the engine bay and makes things easier to work on. And maybe like 1/2 hp gain. Every little bit helps though.
sheachopper
Jul 31, 2019 11:27 AM
Bigold4x4
Sep 28, 2015 05:21 PM
