problem with ignition?distributor?
Old May 25, 2002 | 04:46 PM
jarek5_7's Avatar
hi
for couple of days I`ve got this problem,
I start the car, it can start and run well or it can start with the crazy think I will describe later.
suddenly it goes crazy, just like a half of cylinders were not firing,
exhaust booms, engine shakes very strongly, rpm tach showa from 0 to high rpm, its undriveble in this condition, and suddenly it can go back to normal.
itssomething with ignition.
spark plugs are new, cables are new, cap` new, rotois ok, I`ve even got new module but thats not it....
today car was runing good, I was waiting for it to go crazy, it got warm, i`ve turn fan on, drive a 200 m and than i did go crazy...
I dont know what it could be??
what should I check?
vacum somewhere?
and the strange thing is it can run good or crazy just like he wants it to....
Old May 27, 2002 | 06:07 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Might want to start with checking for trouble codes
Old May 28, 2002 | 01:06 PM
tpi_roc's Avatar
Doesn't sound like a vacuum leak to me....
IF its ignition its est/esc
but you said you replaced the module so that narrows it down.
Check your fuel pressure, check your FPR, and check for codes. Besides those things I'd say its one of the above ignition components.
Old May 28, 2002 | 06:10 PM
jarek5_7's Avatar
fuel pressure has nothing to do with it because it does so
on the gasoline and on the gas-lpg,
tommorow I`ll replace coil and distributor
I hope that`ill do it, but if not what could it be?
I doubt that knock sensor could do somthing like that.?
I have to do it fast cuz 8.06 is
http://www.jarek.arjmm.pl/zlot2002eng.html
Old May 28, 2002 | 06:18 PM
Mike89GTA's Avatar
It might be the distributor, I had the same exact problem and when I took the distributor apart, the shaft had separated where it attaches to the reluctor wheel.
Old May 31, 2002 | 12:12 PM
jarek5_7's Avatar
problem solved
turned out that when I had bad ground and I wanted to strart the car, battery went dead, I`ve connected another batterry,
ad when I turn on the key, 2 pins in ecm fried, both - ground
ground went thru them,
and they were shortcirtuiting,
eariler i`ve chandeg cables,cap, distributor, coil, and nothing changed
then I checked there and there was it
finnaly
Old May 22, 2003 | 12:55 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Could you elaborate onto how you tested the "fried pins"?
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
