Two questions
Old May 26, 2002 | 07:04 PM
worldofool's Avatar
Two questions
I have a 87 GTA 350 L98
1)are L98's 2 or 4 bolt main caps?
2)can i remove the vacume canister by the battery tray without having problems. It doesn't seem those vacume lines do anything important.
Old May 26, 2002 | 08:39 PM
Slo86TA's Avatar
on my 86 TA, I have removed the smog pump, charcoal cannister, and egr lines that run across the exhaust and the car still runs fine. as for the engine having 2 or 4 bolt mains, I'm not sure on that. I do know that if it's the original engine, it should be a 1 piece rear main seal.
Old May 26, 2002 | 09:05 PM
Morley's Avatar
Re: Two questions
Do you have emmisions testing in your area? Do you htink you may have testing in your area in the next few years or might move to an area where they have it?
~M~
Old May 26, 2002 | 09:08 PM
Little GTA's Avatar
2 bolt main
I believe the canister your referring to is cruise control related.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
