86 305 to 350 swap?
Old May 30, 2002 | 07:16 PM
mrabney's Avatar
86 305 to 350 swap?
Please help i am new to irocs! I just got an 86 iroc with a knocking 305 and a bad mass air meter i think (wont run above idle with mass air plugged in). i have a 80 350 truck motor i could rebuild for it, however my question is if i want to convert to speed density to avoid the cost of replacing the mass air meter do i need a new ecu and wireing harness and what year model chip would i run to copmensate for the 350.
Old May 31, 2002 | 12:47 AM
robert1's Avatar
Just get the 7730 ECM, and the chip from a 90-92 Speed Density setup. The wiring harness shouldn't matter. You might also need a different knock sensor. Good luck.
Old May 31, 2002 | 08:41 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you do a search for "Mike Davis" you'll find a link to his website. He did a MAF to SD swap. There are some minor modifications necessary to your harness, as well as to the knock sensor. Or you could just buy a Wells MAF with a lifetime warranty.
Old May 31, 2002 | 02:47 PM
mrabney's Avatar
where do i get a wells mass air sensor
Old Jun 1, 2002 | 10:11 PM
Jim85IROC's Avatar
do a search for wells su 145. There's a place in buffalo that stocks them and gets $166 shipped. Cheapest MAF on the market, highest flowing on the market, most reliable on the market, and the only one with a lifetime warranty.
I'd do the search for you... but I'm too lazy. I bought one from the buffalo place. They shipped it fast, and so far it's working flawlessly.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
