Questions about swaping ecm and prom
Old Jun 9, 2002 | 11:04 PM
poncho9789's Avatar
I have a 89 gta with 350 tpi and I also have a 88formula with a 350 tpi engine in it.
Can I use the prom from my gta in the formula?
The main thing I am worried aobut is the cold start injector that is the only thing that I could not see working with the swap I have planed. I would go out and try it myself but I am having problems getting the car to run correctly without trying to figure out if the prom is part of my problem.
Old Jun 9, 2002 | 11:17 PM
poncho9789's Avatar
the gta prom also has the vast disabled so I am not really worried about that. unless I will still have a problem with that too.
Old Jun 10, 2002 | 12:06 PM
tpi_roc's Avatar
Do they both have the same tranny?
Old Jun 10, 2002 | 12:46 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Just pull the harness of the CS injector and it should work fine. I'm running the $6E '89 prom in my car.
tpi_roc: Read his sig, they're both autos.
Old Jun 10, 2002 | 02:37 PM
tpi_roc's Avatar
I never read sigs
stalkier
Dec 6, 2015 11:25 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
djmarch
Aug 10, 2015 08:42 AM
