STEALTH RAM pricing? and is it worth getting
Old Jun 12, 2002 | 04:46 AM
onebadta's Avatar
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
hi I'm somewhat interested in getting a stealth ram.what all can i uses off my old TPI system....how much is the kit....at summit its around $700.00 i've saw a few posts that list it at $400.00...
any info will be helpful
Old Jun 12, 2002 | 07:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If summit quoted you $700, you looked up the wrong stuff. The prices, as well as the part numbers have been posted a million times and will be easy to find with a search.
Old Jun 12, 2002 | 07:36 AM
a73camaro's Avatar
LOL at the exploded view of the search button!
Old Jun 12, 2002 | 07:42 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks to brad, For reminding me that Thunder Racing has it.
Its about 455 bucks for the intake and fuel lines.
Old Jun 12, 2002 | 10:10 AM
tpi_roc's Avatar
:hail: thunderracing
Old Jun 12, 2002 | 10:53 AM
SMOKEN's Avatar
would this be a good thing to get for a 305 tpi 86
Old Jun 12, 2002 | 11:51 AM
tpi_roc's Avatar
I'd imagine it would be a bit over kill.
Old Jun 12, 2002 | 12:08 PM
Jim85IROC's Avatar
That's WAY too much for a 305. The stealth ram flows almost 300cfm per runner. The 305 probably doesn't need 300cfm for the whole motor. Stick to a long tube runner setup for the 305 so you can still make enough torque to turn the tires.
Old Jun 12, 2002 | 01:06 PM
BenDoe91z28's Avatar
when i get my stealth ram in late june i'm gonna put it on my 305 just for kicks. I ordered it for my 350, but I'm not gonna be able to contain myself. I'll post the results when i get done. he he he
Old Jun 12, 2002 | 02:14 PM
Jim85IROC's Avatar
My crystal ball says that you'll gain 20-25hp at 5500 RPM, and lose 50 horsepower at 3,000 rpm.
Old Jun 12, 2002 | 02:53 PM
tpi_roc's Avatar
peak torque, 100
Old Jun 12, 2002 | 02:56 PM
So here's the plan. I'll run an 1/8th mile pass, I'll put on the stealth ram, spend a few days "perfectly" tuning the computer, then run another 1/8th mile pass just for giggels. Post the results so people can see that too big of intake = bad
Old Jun 12, 2002 | 08:23 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I doubt it'll do that bad. You WANT the intake to outflow the heads by a good amount to make power.
Old Jun 12, 2002 | 08:57 PM
Jim85IROC's Avatar
Ed, Doug Flynn lost over 30 hp at 3,000 RPM on a stock L98 with the stealth ram, so the 305 has to be looking at AT LEAST as much of a horsepower loss (though I'd guess more), and it's not going to make it up on the top end because the TPI isn't nearly as much of a restriction on the 305, especially with the **** peanut cam.
Old Jun 13, 2002 | 12:12 AM
TheRoc88's Avatar
So whats the deal with this "Stealth Ram" thing? I was lookin at gettin the TPIS Mini-Ram but I saw the Stealth Ram at Thunder Racing and now I'm torn.. lol, I'm also gonna throw a Hot Cam w/ 1.6 RR's in the motor this summer too.. Ofcoarse, a "Custom PROM" is in the works too
Anyway, whats the story w/ this Stealth thing?
Oh, and Jim.. I went to your page and realized, when my IROC was in the shop gettin fixed up after a minor "Winter Accident" That I was near obsessed w/ your project on restoring the 85.. EXCELLENT Job man, :hail:
Old Jun 13, 2002 | 07:08 AM
Jim85IROC's Avatar
Thanks.
As for stealth ram info...
It's been beat to death a hundred times. Just do a search and you'll know as much as the rest of us.
Old Jun 13, 2002 | 11:41 AM
Matt_91RSTPI's Avatar
You're the man Jim. That pic is great. I think I'll "Right Click - Save As" so I can thow it up every once in a while too.
-Matt
Old Jun 13, 2002 | 02:14 PM
Jim85IROC's Avatar
I can't take credit for it. Somebody on ne3g made it, and Brad has adopted it since. I more or less borrowed it from him.
It is pretty useful though, because not only does it get our point across, it provides those who didn't know about that feature a nice visual to help them find it.
Old Jun 13, 2002 | 04:49 PM
Ed Maher's Avatar
Car: 04 GTO
In case you didn't notice, BenDoe is talking about a 91 1LE 5 spd car with ported and cut for larger valve stock heads and a sweet cam grind for a 305. I'd say he has a lot of room to improve over a stock TPI set-up.
Oh sure he'll lose some low end torque. Maybe even 50hp worth. I think the gains up top will more than make up for it though. You can't make peak torque in the low 3k range and have a fast car at the same time, you have to be realistic. Being that he is stick, as long as he can effectively drive it i think he'll be fine. Even in an A4, my 3k+ flashing vigilante is very driveable and would definitely be faster with more power in the 4k+ region, no matter how much i gave up in the 3k-4k region, i only spend under a second in that RPM range anyway, who cares about power at 3k? Christ, i've spun off the line at this point and still cut 1.8 60's, a little less power at 3k would be a nice change...
Since he's actually going to try it and give us results i guess we'll see for sure though.
J-money
Jan 4, 2019 09:45 AM
Stangski09
Nov 14, 2015 01:27 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
pimprs
Sep 10, 2015 03:34 PM
09ave
Sep 7, 2015 06:03 PM
