Opinions on cam for my 305
I am rebuild the 305 in my 92 B4C and wanted to know what you all think about 2 cams I am looking at.
First the motor is getting bored out .030, pocket porting the heads and gasket matching the intake. It has headers and cat back on it and I can burn my own chips. Its a 5-speed car with 3.42 gears in the rear end.
The 2 cams I am thinking about getting are both from comp
Cam 1 XR258HR
206 212 480 487 110
Cam 2 XR262HR
212 218 487 495 110
The car will have to pass emission testing, I am thinking that cam 2 may be a little big. The car will be my everyday diver for about a year so it needs to get good gas mileage.
So what do you think, anybody running either cam?
Thanks guys
Cam 1 XR258HR
206 212 480 487 110
Cam 2 XR262HR
212 218 487 495 110
Thanks guys
Guest
Posts: n/a
The first will act like stock, not too much different besides a 1.6 rocker swap except thats more lift than you'd get from doing that. The second will idle and run fine, I've run a 212 intake duration cam on a 305 and it idled and ran quite well.
Use a 112LSA. Your computer will thank you.
