Quick Question, Fuel rail fitting size
Old Jun 14, 2002 | 12:32 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Quick Question, What size is the fuel pressure test fitting on the fuel rail, -4n?? Also if you unscrew the fitting from the fuel rail what is the size of the treads in the fuel rail?
Old Jun 15, 2002 | 12:39 AM
89ProchargedROC's Avatar
the fitting is -4 AN
not sure on the threads......you will go crazy trying to find them though
if you need that port for something, just unscrew the valve in the tester
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
knight72
Aug 10, 2015 09:32 PM
92projectcamaro
Aug 6, 2015 01:20 PM
