ZZ4 cam work w/ my CRATE MOTOR?
Old Jun 15, 2002 | 01:11 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I've searched the archives, but dont know if those answers would apply to me since I have a new crate motor. Do I have to worry about too much lift? The zz4 cam's max lift is .474/.510. My engine is less than a year old.....a 9C1 caprice police crate motor. I'm pretty sure I'll need to put in some different springs....but anything else?
Old Jun 15, 2002 | 05:44 AM
Z28DJP1987's Avatar
Police crate motor??? What is it???
Old Jun 15, 2002 | 01:26 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
It's a GM crate motor....but it's the same design as the 9C1 motors...which are the motors that came in the 91-93 caprice police cars. LT1 bottom end, but w/ a peanut cam...and i'm not sure about the heads.
Old Jun 15, 2002 | 01:35 PM
Bort62's Avatar
Welllllll.....
Considering We have No Idea what heads you have, its hard to say if thats too Much Lft.
My guess would be No, But Do you really feel like testing my guess ?
As far as It having a lt1 Bottom End, I don't think so
Old Jun 15, 2002 | 01:54 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Originally posted by Bort62
Welllllll.....
Well if you really wanna test my KNOWLEDGE of what motor I have....have a look for yourself at Paceparts.com. Part #12513151. Caprice TBI engine. "We have found a "diamond in the rough" in this little Goodwrench replacement. This motor incorporates the same bottom end components as the production LT1 used in the Camaro and Corvettes.
Nodular Iron cast crank
Hypereutic pistons
Lt1/Lt4 Powdered metal connectiong rods
factory hydraulic Roller cam (not an LT1 cam as I stated)
64cc, 1.94/1.50 cylinder heads (not LT1 as I stated)
So next time you wanna insult a guy by telling him he doesn't know what kind of motor he has.....take a look first. The LT1 is not a super engine...is it that far fetched that it shares the same parts w/ another motor? You think that just because you dont know what a 9C1 motor is means it's a POS? The caprice police car had this motor from '91-93...in '94 it changed to the LT1....the only changes made were the cam, heads, and intake....my motor has the SAME BOTTOM END COMPONENTS AS THE LT1. are you sure what's under your hood?
Old Jun 16, 2002 | 12:15 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Heads
I believe it comes with 193 swirl port heads. You can use the ZZ4 if you get the retainers that lift .050 and use the LT4 or new ZZ4 springs. They need to install @ 1.750.
HTH,
Don>>>
Old Jun 16, 2002 | 12:52 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Re: Heads
HTH,
Don>>>
Exactly what I was looking for...thanks.
FormulasOnly
Jul 23, 2018 08:47 AM
Giocio
Oct 1, 2015 12:20 PM
