Sensor question
Old Jun 15, 2002 | 08:12 AM
JHNBOY9's Avatar
Sensor question
My 305 TPI is getting very poor fuel mileage. The check engine light came on and I ran a code check on it with a paperclip. I is code 44 lean exhaust, is that a bad O2 sensor?? Other than the fuel mileage the car runs great.
Old Jun 15, 2002 | 12:55 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Generally yes. If it's getting old it'd be a good idea to replace it.
According to my Helms manual it could be caused by many other things as well.
1 O2 sensor wire (mispositioned/contacting exman)
2 MAP sensor
3 Lean Injectors (clean 'em)
4 Fuel contamination (water in tank)
5 Fuel pressure (pump going bad, check under load)
6 Exhaust leak (unlikely)
7 AIR system
Easiest thing to do would be to just replace the O2
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
