Using TPI system on older engine
Old Jun 16, 2002 | 12:29 AM
David Culpepper's Avatar
My cousin has a '87 Iroc. The original motor(305) is locked up and he is going to build a 350 for it. He wants to use a older style(pre'86) block and use the existing TPI setup on it. Are there any problems that we may run in to? If so, what are they and can/how do we fix them? Any help would be much appreciated.
Old Jun 16, 2002 | 09:33 PM
Just movin this up.
Old Jun 16, 2002 | 09:35 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well. Are you planning on using the same heads? those are different, slightly.. Also the flywheel will be a once peice rear vs a two peice rear, maybe.
You can drill the center bolt holes a little bit on your intake to take account for both style heads..
-- Joe
Old Jun 16, 2002 | 10:09 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The only problem will be the center bolt holes on the intake manifold. But those can either be slotted to work, or just get an intake base from an '85 or '86 car.
midge54
Dec 27, 2019 04:14 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
