Fuel problems in stock 305TPI
Old Jun 16, 2002 | 10:40 PM
youngbuck007's Avatar
I've got a bone stock 87' TA with a 305TPI. I have owned the car for 4 years now and have had very few problems with it. However, I am baffled at my current problem. Under the hood on the passengers side near the headlamp is a round canister. This is a charcoal canister which is supposed to dissipate fumes from the gas tank. For some reason I am getting a lot of gas to leak out of this canister when the car runs. I have replaced the canister and all the tubes leading to it, and have also put a vented gas cap on the tank in case the tank was somehow pressurizing the fuel line and sending fuel down it, but I still have a fuel leak out of the cannister. Any help would be IMMENSELY appreciated!!
Old Jun 17, 2002 | 02:18 AM
Morley's Avatar
How is your fuel pressure? Also check the solinoid on top of the evap cannister, when the car is running it should be warm/hot. That solinoid is energized when the car is running and deenergized when off. If it isn't warm it may not be energizing and might cause your problem.
~M~
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
