stealth ram clone for hood clearance
Old Jun 18, 2002 | 03:15 PM
grumpyvette's Avatar
http://www.cfivevette.com/forums/sho...&threadid=2306
Old Jun 20, 2002 | 08:13 PM
poncho9789's Avatar
Now that is schweet I was going to make something like that to get over the very long tubes of the ltr setup.
I have also seen the basicly same setup but he used the stock plenum but made covers for the long tube setup and milled the bottom of the thing flat and put the holes for the air to flow into the base.
Old Jun 20, 2002 | 08:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's a thread on corvetteforum.com about that too. Another alternative might be to use the plenum from the street & Performance big block setup. It looks just like a stock TPI plenum, except that it sits on top of a Tunnel Ram EFI base.
EDIT: Here's a thread I started on chevytalk.org that covers what I'm thinking:
http://www.chevytalk.org/forums/Foru...ML/000726.html
Old Jun 21, 2002 | 02:51 PM
Jza's Avatar
Jza
Wonder how he finally mounted the fuel rails.. Those look a lot like stock TPI fuel rails just held there with the injectors themselves.
Old Jun 21, 2002 | 06:10 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Looks like hes using TPI rails, seperated and flipped side to side.
Old Jun 22, 2002 | 09:05 AM
DVC-Racing's Avatar
Saturn.
You´re absolutely right.
Angle of the injectors put the rails under pressure when you bolt down the plenum ontop the ram.
Works great.
Old Jun 22, 2002 | 09:16 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
DVC. got your 1st e-mail. Did you ever get my reply?
on dimentions of the plenum, tb's etc?
Chris
Old Jun 22, 2002 | 11:27 AM
DVC-Racing's Avatar
I´ll check my mail.
cowansauto
Apr 3, 2025 12:51 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
L98GTA87
Oct 19, 2015 10:43 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
