tpi base
Old Jun 18, 2002 | 07:41 PM
JMDinHawaii's Avatar
tpi base
Are there any differences in OEM tpi bases through the years?? Are they the same from 85-92?
Old Jun 18, 2002 | 10:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
85-86, 87-92 f-body are almost the same but, the center holes to the head are on a differant angle. the vette intake uses a plumed in tube for the egr. the same should apply for the bolt holes
Old Jun 19, 2002 | 07:33 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Keep in mind that the Corvette base is different from the f-body base as well.
Old Jun 19, 2002 | 12:37 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The center holes on the Vette manifolds are the same as the rest. F-bodies 1987 & up are at different angle. As stated the Vette has an external EGR pipe.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
