Carb intake converted to multi-point
Old Jun 29, 2002 | 10:55 PM
Dan W's Avatar
My Mult-point conversion is finially running... thought you guys might like this. Its an Edelbrock Victor Jr on AFR 195 heads with a 700cfm Holley tb unit that I had from a previous project (minus the TBI injector pod). I'm running DFI.
Had I used AFR 190's instead of the taller port 195's I could have used an off the shelf intake and would not have had to farm out the intake conversion. Putting together the braided hoses was easy. I just plugged off the fuel line inlets into the TB unit. I drilled a couple of holes in a 1" spacer for my vacuum ports. I'm running a 2 1/2" drop base air cleaner. This would probably fit under a stock hood if it werent for the spacer.
http://www.fbody.com/members/workman/MultiPoint1.JPG
http://www.fbody.com/members/workman/MultiPoint2.JPG
http://www.fbody.com/members/workman/MultiPoint3.JPG
Old Jun 29, 2002 | 11:07 PM
Dan W's Avatar
I don't know why the links aren't working... if you copy the link and paste it in the address bar it works.
Old Jun 29, 2002 | 11:54 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Nice setup!
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
