TPI HO vs. regular TPI?
Old Jul 7, 2002 | 02:39 PM
89Irocker's Avatar
What is the difference between a regular TPI setup and a TPI HO?
Did one come with an aluminum manifold?
Old Jul 7, 2002 | 03:03 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: TPI HO vs. regular TPI?
There was no TPI HO. There were some SLP parts that could be ordered back in 1992, and still available today (though there is even better alternatives IMO). But there was nothing from GM other than the stock TPI setup. The stock TPI is all cast aluminum.
Old Jul 7, 2002 | 03:05 PM
89BlueTA's Avatar
There is no HO TPI they are all the same, performance wise.
nick
Old Jul 7, 2002 | 03:55 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
The only real difference in or on a T.P.I. engine are 305,350, and a 350 with aluminum heads (VETTE). Other then the SLP goodies.
Old Jul 8, 2002 | 08:47 PM
89Irocker's Avatar
I was just wondering because when I ran a carfax on my current car it said it was a 305 HO TPI.
Old Jul 8, 2002 | 09:32 PM
kvu's Avatar
kvu
The tpi makes it a "high output".But there is no ho tpi option.I have seen 85 305 tpi t/a with a 6 grand redline from the factory though.
Old Jul 9, 2002 | 08:34 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
or an 86 tpi which should have been called TPI L.O. (low output) jk they are the slower of the tpi cars but, still great cars.
Old Jul 9, 2002 | 11:30 PM
Gruvin84SS's Avatar
HO?
the H.O. refers to High Output and it is referring to the L69 motor not the Tuned port intake. So what you have is a 305 HO with TPI.
Whats up Cruzin Kaz? I see you made it over from the monte site.
Old Jul 10, 2002 | 02:49 PM
kvu's Avatar
kvu
whats your vin?
Old Jul 12, 2002 | 01:53 AM
89Irocker's Avatar
1G1FP21FXKL111671
Old Jul 12, 2002 | 01:56 AM
89Irocker's Avatar
One interesting thing, I looked on my car and it does have an aluminum intake manifold and I know I didn't put an aftermarket one on, and the guy I bought it from (the original owner) didn't mention putting one on either, I am now wondering if it came with it stock?
Old Jul 12, 2002 | 02:27 AM
Arawn's Avatar
Mine's listed as an HO as well when I look up the RPO code for our engines (LB9). But there doesn't seem to be much HO on mine, I'll tell ya that
Old Jul 13, 2002 | 12:19 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Hey Gruvin. What's up? Yep these guys over here have been a great help. Hopefully someday I will be able to return the help I've been given. Almost got the Monte back out from my little mishap. Costed me about $300 can. to fix her back up. Have a goo one!
:rockon:
Hey 89irocker. All T.P.I engines had a aluminum intake.
Old Jul 13, 2002 | 08:02 PM
pokes87iroc's Avatar
mine has ho to
LittleFranks
Sep 17, 2015 12:22 PM
gixxer92
Sep 1, 2015 04:32 PM
someone972
Aug 30, 2015 12:52 AM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
