5.7 TPI Cooling FAN troubles........
Old Jul 12, 2002 | 09:10 PM
1991rscamarodem's Avatar
does anyone know why my dual fans aren't working together??? i have replaced both relays and all fuses are fine. when the temp gets high the drivers side fan turns on but my pass. side fan stays off. i check the wiring and replaced the relay, temp sender, and temp switch. Is there something i'm missing??? does one fan work for temp and the other for soemthing else or FROM something else?????? please help guys..i'm hitting 250 before i turn off the engine!!!!!!!!!!!!
Old Jul 12, 2002 | 09:39 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Have you checked the tech articles and cooling it down board ?
Lots of good info there.
Old Jul 12, 2002 | 11:27 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
did you try to turn on the fan that does not work manually? if so, and it still didn't turn, did you try spining it by hand? sometimes the brushs' tend to stick if they sit to long without comin on.
thanks
anthony
Old Jul 12, 2002 | 11:36 PM
craiger's Avatar
I spliced into the white wire that goesto the passenger side cylinder head. Then i put that wire to a 2 pole swithc, grounded it inside the drivers compartment to have manual control over the #2 fan. Easy! It will take you 15 min MAX and about 5 bucks for the swich and the wire.
Old Jul 13, 2002 | 11:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
When the engine is warm try turning on the A/C the second fan should come within 30 sec. Does it come on? The fan motor may be bad.
Old Jul 14, 2002 | 12:04 AM
92superram's Avatar
I read somewhere that one fan is controlled by the ecu, and the other is controlled by a temp switch. The one controlled by the temp doesn't come on till the car gets to 220*. Is this correct?? if so, which fan is which? I need to look and see what my fans do at different temps. I do have a 160* thermostat and chip. I am going to wire one of the fans to a switch, so I can turn it on even when the car is off. I do have some overheating problems when the car idles for a long time in hot weather.
Old Jul 14, 2002 | 12:41 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Yes this is right, the one controlled by the ECM is on the driver side of the car.
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
Leggman1
Aug 6, 2015 04:15 AM
