can someone explain knock sensor to me
Old Jul 13, 2002 | 12:26 PM
TransAm87's Avatar
Hey guys, i am trying to learn a little bit each day about my thirdgen, Can someone pelase explain what the knock sensor does and any other sensors that the motor uses ...
thanks
aj
anything will help about any sensor
thanks
aj
Old Jul 13, 2002 | 01:06 PM
bowtie1983ss's Avatar
Engine: 5.7 Liter Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: 2.77:1 Borg Warner (Stock)
The knock sensor detects knock or pinging of the engine and then generates a low voltage AC voltage signal to an electronic module that is usually mounted on the firewall. That module converts the AC signal to a DC voltage and supplies that DC signal to the computer. The computer then retards the timing of the engine until the knock signal is no longer generated.
Knock typically occurs as a result of low octane or poor quality fuel. It can also occur if your engine has a lot of carbon or in poor mechanical condition or if the distriubutor timing is not properly set.
When the knock sensor signals the computer to retard the timing, you'll lose power as a result. It's designed to prevent mechanical engine damage to pistons, cylinder walls, rings, and valves should a severe knocking or pinging occur.
Even if the knock sensor system is functioning properly, you could notice a light pinging sound as a result of poor fuel quality. It's heavy knocking that the sensor is designed to prevent, so don't go replacing everything without proper testing just because there is a light pinging occuring.
Hope that helps.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
