Cone air filter?
Old Jul 15, 2002 | 09:10 AM
Amrish's Avatar
Cone air filter?
I have seen some of u guys with a Cone shaped air filter attached straight onto the TB and not having the stock air boxes...
Where can i find one of these for my 1992 z28 350 TPI??
I also want to know if anyone has seen any kind of power gain, or does it make a nice sound WOT...
Cause my friends truck makes a reallll loud deep throaty soud when the RPMS are around 3k... but then again, its a truck...
Old Jul 15, 2002 | 09:28 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
i have one in my garage 20 bucks and shipping it is yours
my brother got it for me not knowing a had a mass air flow senser. the filter can only be used on a speed density system
Old Jul 15, 2002 | 10:32 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
keep in mind that you'll only suck in hot air with a tb mounted air filter
cool air good:hail:
hot air bad
Old Jul 15, 2002 | 11:53 AM
Sciguyjim's Avatar
cool air good
hot air bad
Yes, but more air is better than less even if it is warm, don't you think?
Old Jul 15, 2002 | 12:08 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Pv=nRT
Warmer air is less dense than cool air. The more dense the air, the more air you get per unit volume. Therefore, the colder the air, the more air is available to blow gas up. Whether or not more air is better than dense air depends on the limiting factor of your intake. If the filter is maxed out in the cfm department at one temperature, the only possible way to make more power with air at the same temperature would be to use a filter with a higher cfm rating. However, because cold air is more dense (greater amount of air in a cubic foot) colder air is typically always better due to cfm restrictions on intake components.
Old Jul 15, 2002 | 12:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I just took my car to the track comparing a homemade CAI with the RC-5000 cone filter on the end of the plenum.
CAI gave me on average 1/10 of a second and 1 mph.
To me the CAI would be good for the track and on the street I'd go with hooking the cone right to the plenum. I like the sound of the sucking
Old Jul 15, 2002 | 01:00 PM
Sciguyjim's Avatar
I understand how cold air is better. In my case,'89 305 tpi T/A, my stock airbox snorkle was only about an inch from the wall behind my headlights. I was able to turn it a bit toward an opening in the wall but that was all I could do. There wasn't even enough room to route some flexible tubing to the snorkle from a remote location without having to squeeze it between existing hoses & stuff. About a year ago I removed the airbox completely and was able to mount a larger exposed filter in its place. It still gets as little cold air as before but now can also take as much warm air as it wants. It just seems better than the restricted, cold air only arrangement.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
